leggins Posted August 20, 2006 Report Share Posted August 20, 2006 My rev 250 has been causing me unwanted headaches. The last couple of times out I have had a hell of a job getting it started from cold. When it dose start it coughs and pops like a good un. The plug has been oiled up when removed. I am using a mix of 100 cc to 5L is this too rich ? When I replace the plug with a new one it seems to do the trick for a short while then its back to square one . My main concern is when the bike is ticking over it pops constantly unlike other rev 3s Ive listened too...... Any ideas ? p.s I have done the carb mods on r2w ,s site Quote Link to comment Share on other sites More sharing options...
neonsurge Posted August 20, 2006 Report Share Posted August 20, 2006 100cl to 5L is 50:1 which is very rich. Try and 80:1 mix and see how it goes (I've heard of people running up to 100:1 with fully synthetic oil but I don't think I'd try it!) Quote Link to comment Share on other sites More sharing options...
barrybaines Posted August 20, 2006 Report Share Posted August 20, 2006 75:1 is a good ratio which is 67ml of oil too 5 litres but if your like me and not that anal over the measurement anywhere between 60 and 75ml of oil per 5 litres is good Quote Link to comment Share on other sites More sharing options...
scorpa3 Posted August 20, 2006 Report Share Posted August 20, 2006 My 04 did that for about 15 minutes then the stator packed in...... Then five trials later the new stator did the same. Quote Link to comment Share on other sites More sharing options...
betarick Posted August 20, 2006 Report Share Posted August 20, 2006 My 06 rev3 is a complete b--tard to start when cold takes about 20 kicks then it fires up likes it flooded I HAVE ALSO DONE CARB DRILLING MODS and keep trying spark plugs and i run at a mix of 70.1 any one else havin same bother! Quote Link to comment Share on other sites More sharing options...
slapshot 3 Posted August 20, 2006 Report Share Posted August 20, 2006 (edited) What a shower..... Bit of choke, ONE kick, on 70:1 with Silky 2t.....piece of pi$$...though not in with the petrol obviously. Seriously when I got it I put a new plug in and blew through the carb before I kicked it over cos the guy I got it from had problems too. ....maybe it's weight behind the kick.... like the new avatar Barry, (ps she won't let me buy superflous spares........sorry mate) Edited August 20, 2006 by Slapshot 3 Quote Link to comment Share on other sites More sharing options...
betarick Posted August 20, 2006 Report Share Posted August 20, 2006 Belive me theres plenty of weight behind kick my 97 techno went ever 2nd or 3rd kick and that had plenty of compression as i rebuilt engine Quote Link to comment Share on other sites More sharing options...
aj201280 Posted August 20, 2006 Report Share Posted August 20, 2006 Comming from kieth used to be a tech with lampkins 70:1 fully synthetic and 50:1 if running it on semi synthetic Quote Link to comment Share on other sites More sharing options...
barrybaines Posted August 21, 2006 Report Share Posted August 21, 2006 Slapshot 3 said: like the new avatar Barry, (ps she won't let me buy superflous spares........sorry mate) Was that aimed at me? if so I get the avatar bit but not the spares? Quote Link to comment Share on other sites More sharing options...
neonsurge Posted August 21, 2006 Report Share Posted August 21, 2006 betarick said: My 06 rev3 is a complete b--tard to start when cold takes about 20 kicks thenit fires up likes it flooded I HAVE ALSO DONE CARB DRILLING MODS and keep trying spark plugs and i run at a mix of 70.1 any one else havin same bother! That might be because it is (flooded). I had exactly the same problem on my old bike and tried everything to cure it (carb, electrics etc. etc.) to no avail. Then, when I took the engine out to be rebuilt I noticed fuel dripping constantly dripping from the hose, even with the fuel tap off. A seal inside the tap was buggered... you can see where this is going. One quick call to Lampkins to order a new tap and the problem was sorted! Quote Link to comment Share on other sites More sharing options...
slapshot 3 Posted August 21, 2006 Report Share Posted August 21, 2006 barrybaines said: Slapshot 3 said: like the new avatar Barry, (ps she won't let me buy superflous spares........sorry mate) Was that aimed at me? if so I get the avatar bit but not the spares? yup, pm'd you about the hub last week, she found out and I got grief....again!! Quote Link to comment Share on other sites More sharing options...
barrybaines Posted August 21, 2006 Report Share Posted August 21, 2006 Ah yeah makes sense now no worries Quote Link to comment Share on other sites More sharing options...
betarick Posted August 21, 2006 Report Share Posted August 21, 2006 Once mine is started its fine. starts first kick just a t--t when its cold and been stood for a while also i use repsol oil? Quote Link to comment Share on other sites More sharing options...
kinell Posted August 21, 2006 Report Share Posted August 21, 2006 Mine started 1st kick last week after being stood for over 3 months! I use 75ml of 'PJ1 Silverfire' oil per 5 litres of ordinary (stale?) unleaded petrol. Turn fuel tap on, choke on, one full turn of the throttle and kick it with a smidge of open throttle Quote Link to comment Share on other sites More sharing options...
betarick Posted August 21, 2006 Report Share Posted August 21, 2006 Thats how i was told to start it kinell but its not having it. Had no problem with my old techno! Quote Link to comment Share on other sites More sharing options...
