manxlass Posted December 1, 2003 Report Share Posted December 1, 2003 Does anyone know how to stop the drag on my bike. It is driving me up the wall. Not literally, I can't do walls yet It's a 2003 125. It was really bad yesterday. Usually, it goes after the bike has warmed up. Any advice would be greatly appreciated by my husband, because I am driving him up the wall as well. Quote Link to comment Share on other sites More sharing options...
hrc2002 Posted December 1, 2003 Report Share Posted December 1, 2003 Hi Sue, Check this link on Clutch drag, the explaination given is for a 93, but I think you might be able to get some answers from it. Gas Gas Help Pages - Clutch Drag Good Luck HRC Quote Link to comment Share on other sites More sharing options...
hoodie2 Posted December 1, 2003 Report Share Posted December 1, 2003 I managed to get rid of drag in my TXT280 by reducing the quantity of oil from 750cc to 650cc. I use TQF automatic transmission oil and change it quite regularly, usually when the drag starts to come back. After about 2 months the oil starts to lose it's properties and drag re appears. Hope this helps. Quote Link to comment Share on other sites More sharing options...
brucej Posted December 3, 2003 Report Share Posted December 3, 2003 Air in the clutch system can also cause drag. The symptoms on my bike were that the clutch lever had to be pulled in right to the handlebar to make it release; even then it had more drag than it should have. It took me several tries at bleeding it before I got it right. It was very frustrating because I was never sure if the problem was elsewhere, or if I just wasn't getting all the air out. I hope you solve yours quicker than I did mine! Quote Link to comment Share on other sites More sharing options...
