roberto Posted August 28, 2006 Report Share Posted August 28, 2006 Hi, I am rebuilding a MontesaCota 350 and have a problem getting the primary drive gear off the crank...it simply wont come off. The nut on the weighted flywheel seemed to be overtightened and now the gear is a bear to deal with. I have messed up a brand new extractor...any ideas?? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted August 28, 2006 Report Share Posted August 28, 2006 If you are talking about a 348 or 349 Cota, the primary pinion is on a taper and yes it takes quite a bit of force to get it off. Finger type universal pullers are not strong enough. I made a simple tubular puller which worked a treat. If you need help with how to make a puller, let me know. Quote Link to comment Share on other sites More sharing options...
toofasttim Posted August 28, 2006 Report Share Posted August 28, 2006 Yup been there. Large industrial puller, gas flame and someone who doesn't care very much for life. Quote Link to comment Share on other sites More sharing options...
roberto Posted August 29, 2006 Author Report Share Posted August 29, 2006 If you are talking about a 348 or 349 Cota, the primary pinion is on a taper and yes it takes quite a bit of force to get it off. Finger type universal pullers are not strong enough. I made a simple tubular puller which worked a treat. If you need help with how to make a puller, let me know. Ya, I would be interested in seeing the puller, the nut on the weighted flywheel was over torque, i am rebuilding three engines at the moment, 2 348 and the 350, the 348's have gone smoothly, but i've had nothing but problems with the 350...this gear is on very, very tight. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted August 30, 2006 Report Share Posted August 30, 2006 Pinion puller photos sent by email to Roberto Quote Link to comment Share on other sites More sharing options...
