endo kid Posted September 6, 2006 Report Share Posted September 6, 2006 ,05 sherco rear wheel Did the Sherco rear wheel just fit on there or did you have to do a lot of work to make it fit? All you need to do is just get some spacers made for each side of the wheel and the one for the spindle inside the hub.If you want the measurements for the spacers let me know and i will measure them and post the measurements on here Quote Link to comment Share on other sites More sharing options...
sirhc Posted September 7, 2006 Report Share Posted September 7, 2006 (edited) All you need to do is just get some spacers made for each side of the wheel and the one for the spindle inside the hub.If you want the measurements for the spacers let me know and i will measure them and post the measurements on here Ya, that would be great I would appreciate the measurements. Back to the main subject, seeing the new Sherco's it says all the changes are for 125 on up. Could they be making a new 80? I also like one of Alan's ideas, since your son is moving down get a Sherco 125 and put a 80 top end on it. That way if he is old enough in a year or two you could just put the 125 top end back on Edited September 7, 2006 by sirhc Quote Link to comment Share on other sites More sharing options...
