zanx Posted September 11, 2006 Report Share Posted September 11, 2006 Maths not being my strong point, I've been looking at those fancy pre-mix containers like the Accu-Mix. Problem being that the Accu-Mix apparently only goes to 50:1 when the Montesa manual states 80:1 (or maybe 70:1). Has anyone got round this problem or bought a similar product? Quote Link to comment Share on other sites More sharing options...
seandellear Posted September 11, 2006 Report Share Posted September 11, 2006 Hey If you look at this chert it tells you how much oil to add to a gallon (5 litres) of petrol Hope this helps sean two_stroke_mixtures.pdf Quote Link to comment Share on other sites More sharing options...
zanx Posted September 11, 2006 Author Report Share Posted September 11, 2006 Hey If you look at this chert it tells you how much oil to add to a gallon (5 litres) of petrolHope this helps sean Oooh, thanks Sean and thanks John Hird, whoever you are Quote Link to comment Share on other sites More sharing options...
barrybaines Posted September 11, 2006 Report Share Posted September 11, 2006 I stumbled across this very trick little calculator for mixtures HERE Quote Link to comment Share on other sites More sharing options...
ralph Posted September 11, 2006 Report Share Posted September 11, 2006 Great chert Barrybaines.If your mix is 80:1 you can buy a 10Litre can put in the 8 Litres add 100 millilitres of oil or 1/2 the amounts if you haven't enough room in the can. Quote Link to comment Share on other sites More sharing options...
stevec Posted September 12, 2006 Report Share Posted September 12, 2006 Just use the 40:1 amount and add it to two gallons instead of one. Quote Link to comment Share on other sites More sharing options...
