charlie Posted September 13, 2006 Report Share Posted September 13, 2006 My lovely gasser 300 05 sometimes (quite rarely) will not start when warm. Particulary, after ive just looked at a section. bummer. i do look after it . Anybody got any tips ? Quote Link to comment Share on other sites More sharing options...
brian r Posted September 13, 2006 Report Share Posted September 13, 2006 Change the plug and make sure the idle screw is adjusted properly. Quote Link to comment Share on other sites More sharing options...
perce Posted September 13, 2006 Report Share Posted September 13, 2006 knock it into gear & rock it, should start straight away. Quote Link to comment Share on other sites More sharing options...
essex rider Posted September 14, 2006 Report Share Posted September 14, 2006 Firstly put it on classified ads, then take someones money and give them bike, buy new beta....... simple No on a serious note check the kill switch isnt sometimes shorting out. Quote Link to comment Share on other sites More sharing options...
charlie Posted September 22, 2006 Author Report Share Posted September 22, 2006 thanks for advice . it was great. Quote Link to comment Share on other sites More sharing options...
sirdabsalot Posted September 24, 2006 Report Share Posted September 24, 2006 I also have an 05 300. If I twist the throttle even a little when trying to start, it won't. Don't touch the throttle! Cheers, Richard Quote Link to comment Share on other sites More sharing options...
beta123 Posted October 17, 2006 Report Share Posted October 17, 2006 I have the same problem with my 05 300 gas gas - is yours fixed? how did you do it? Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted October 18, 2006 Report Share Posted October 18, 2006 In 05 I swapped from a sherco 290 to a 300 pro and experienced the same starting problems, my friend however [a long time pro owner] could start it first kick hot or cold. It took me a while to work it out but I finally figured NO THROTTLE as you kick[and you need a decent kick] as the kick start stops and the motor starts to spin open the throttle a small amount and it should fire every time. Head spacer does make it easier to kick over if thats your problem Hope this helps Quote Link to comment Share on other sites More sharing options...
bri8617 Posted October 20, 2006 Report Share Posted October 20, 2006 been on to gasgas uk about this ,they recommended altering the float height from 18.5 mm which is standard down to 17mm .this should sort out starting problems when the bike is hot ... hope this helps Quote Link to comment Share on other sites More sharing options...
bikespace Posted October 21, 2006 Report Share Posted October 21, 2006 One of our bunch borrowed a Gasser 300 for the Manx 2 day. He had a mare starting it. Every time I get on this bike it starts first time. It is totally down to the size of the right leg. I'm sure the other things would help to make it easier, but it may just be that it needs a bigger kick. Quote Link to comment Share on other sites More sharing options...
