wilsonwash8 Posted September 14, 2006 Report Share Posted September 14, 2006 Hi, Another question. While assembling the TLR 200 motor, I installed a new D.I.D. cam chain that I got from John at the Classic and Pre 65 TY Shop in the UK. Stock Honda calls for 100 link. This chain is 100 link. Long story short - it was a pretty tight fit. Tight to the point that the tension of the chin caused the rear of the cam to ride up and out of the rear cup a bit. I was able to hold the cam down and assemble the cover, but even with the tensioner at full slack, the chain is pretty snug. I started the bike and noticed a slight knock or slap that appears to come from the lower end. As the RPM's rise, the noise goes away. since I didn't break into the lower end on rebuild, I can't say for certain that the mains are ok. The chain was an endless unit that came with a master link for those wanting to be able to remove the chain without splitting the motor, but I chose to go the full cicuit route. I laid the old chain next to the new one before assembly and noticed a bit of difference, but not enough to fret over. The old one was pretty well tweaked like everything else on the bike. I just wanted to get an opinion before I potentially ruin the motor. Do you think that break in will allow the chain to stretch enough? I fear premature wear on the lobes and rockers, not to mention breakage. I might mention that I installed new chain guides as well. Your thoughts? Thanks. Brian Quote Link to comment Share on other sites More sharing options...
brian r Posted September 14, 2006 Report Share Posted September 14, 2006 I thought it was a 104 link. Quote Link to comment Share on other sites More sharing options...
barfy Posted September 15, 2006 Report Share Posted September 15, 2006 I had a knock that sounds similar to yours on my RTL; sever knock at tick over but went away at higher revs. I rebuilt the topend because I didn Quote Link to comment Share on other sites More sharing options...
g4321 Posted September 21, 2006 Report Share Posted September 21, 2006 Cant remember chain length but the difference between a 104 and 100 link chain would be obviousle. The new chain will be tight - have you pushed down the chain tensioner to fully slacken it? Its certainly noticable on a 250 and 200 if you fit a thicker base gasket that the chain is very tight whrn first fitted. AS for bottom end try for up and down play on the ignition flywheel - if there is any strip and replace bearings, they are expensove being Honda one off's rather than std sizes . Gordon Quote Link to comment Share on other sites More sharing options...
