grouchof Posted September 15, 2006 Report Share Posted September 15, 2006 Hi, I was working on my cota 349 earlier model (80 I think), because the crank is broken. I am surpise because this crank looks like Quote Link to comment Share on other sites More sharing options...
roberto Posted October 8, 2006 Report Share Posted October 8, 2006 I believe the cranks are the same. The bearings used, cranks weights and electrics are all the same as far as I can see. I have two engines on my bench right now. It is true that the 349 show a asymetric cranks wehere as the 348 are round. I don't think there is any difference in the crank case halves. Was the engine running when you took it apart? Quote Link to comment Share on other sites More sharing options...
grouchof Posted October 9, 2006 Author Report Share Posted October 9, 2006 Hi, I got info from another source, saying the early 349 have the same crank as the 348. So I need to find a 348 crank ! Regards Quote Link to comment Share on other sites More sharing options...
