mcd Posted September 18, 2006 Report Share Posted September 18, 2006 Hi, I hope somebody can help with an Aprilia Climber 280R 1994. First problem is that when the flywheel is removed there is a space where one of the magnets is missing! how many should there be? 5? if so can anybody tell me where I can get one and also it looks like it needs a new stator so one of those aswell! thanks Quote Link to comment Share on other sites More sharing options...
lineaway Posted September 18, 2006 Report Share Posted September 18, 2006 Usually when all this happens the main bearings have gone bad. Try moving the crank to see if you have movement. You do not want to install a new stator and flywheel without replacing the mains. Quote Link to comment Share on other sites More sharing options...
zanx Posted September 19, 2006 Report Share Posted September 19, 2006 If your stator is nadgered then West Country Windings will be able to re-wire it. If a magnet has fallen off then it'll be stuck to something or smashed into a million bits surely? Quote Link to comment Share on other sites More sharing options...
mcd Posted September 19, 2006 Author Report Share Posted September 19, 2006 The last cowboy to have the bike must have smashed the magnet and removed it before sale so one is required. Main bearings must have been done as they are in ok condition. Quote Link to comment Share on other sites More sharing options...
zanx Posted September 19, 2006 Report Share Posted September 19, 2006 The last cowboy to have the bike must have smashed the magnet and removed it before sale so one is required. Main bearings must have been done as they are in ok condition. I hope this isn't my old bike. Is it green/white/red and in really good nick except for mangled fork top bolts? Quote Link to comment Share on other sites More sharing options...
