Taming Down Those Beasts
j@mes
Im not sure about the difference a flywheel weight makes but fitting a head spacer and a slow action throttle to a gasser certainly does the trick - I ride an 06 280 pro and i've just fitted both - helps with the grip in the wet but still pulls when you need it!
