ritcrider Posted September 20, 2006 Report Share Posted September 20, 2006 The spark plug in my 02 Pro is black and sooty....not a nice tan color and I'm getting smoke and splooge out the exhaust. Apparently she's running a little rich so my question is should I change the main, pilot or drop the needle a notch (I'm assuming it's adjustable like most?) I'm at sea level so any jetting info would be helpful. Just rebuilt the top end so the engines nice and crisp....air filter is clean and oiled. I'd like to get the throttle reponse cleaner as it is a tad bit blubbery off idle. Many thanks Quote Link to comment Share on other sites More sharing options...
steve fracy Posted September 20, 2006 Report Share Posted September 20, 2006 Go to a 38 pilot and a 112main and she'll run right as rain! Make sure to check your exhaust and especially the middle section as this can drastically alter performance. Quote Link to comment Share on other sites More sharing options...
ritcrider Posted September 21, 2006 Author Report Share Posted September 21, 2006 Thanks for the info I'm assuming you mean to make sure the packing/muffler isn't clogged? Quote Link to comment Share on other sites More sharing options...
tobster Posted September 22, 2006 Report Share Posted September 22, 2006 RIRCrider - surely if your bike had been running OK, but is not running rich, then this implies something is not right (sounds so much better than wrong). To change your jetting or adjust the needle height won't solve the problem but merely mask it. So I would investigate the usual reasons that can make a bike start running rich eg blocked/dirty air filter, poor plug/ignition, then move on to exhausts BEFORE you start replacing jets etc Quote Link to comment Share on other sites More sharing options...
ritcrider Posted September 22, 2006 Author Report Share Posted September 22, 2006 Sorry, let me clarify I bought it used from Ohio (USA) and it has always run on the rich side. Not to the point where it runs bad or anything but the plug has always been a little black and sooty and exhaust smokes a little. I just rebuilt the top end, new barrel, piston and rings and it runs and starts easier than it ever did since I got it. Runs nice and quite also (Bad rattle before due to excessive piston cylinder clearance) It is showing a still rich condition on plug reading. Air cleaner is new, clean and freshly oiled son intake is not a problem. I'd just like to get the plug running nice and tan. Throttle responce isn't to bad...maybe slightly bluberry off idle. Quote Link to comment Share on other sites More sharing options...
