Airbox Fix
hop blip and a jump
Anyone out there got a fix it for the gasser pro airboxes?????
i've heard lots of different things to do, what'll stop the water and mud gettin in????????
I'm fed up of people telling me to buy a beta instead coz you don't have to clean the airboxes out! :P
Edited by rockhopper
Split the airbox and seal the joints properly with RTV sealant. Should have been done at PDI. Once you have done it - just maintain as normal. No need to buy a Beta. Worst case if you have damaged the bottom half of the air box it will cost you
much the same as above
best i have found is to split air box and put a bead of sicoflex 50 or similar ( any windscreen mastic should do) around the join and then put back together
then add extra at the top back of air box where the rear guard comes down
this stuff hardens but remains flexible whereas silicone stays to soft and gets pulled out too quickly
