Chain Wear
gasgasssser
Is it normal for the chain to wear out before the sprockets??.I`ve recently taken a link out of my chain `cos i couldnt take the slack out with the snail cams.While i was messing with it,i noticed that the rollers on the chain are sitting on the foward flank.Looks worn.What do you think.
PS the sprokets are fine.
Steve
Betarev3 is absolutley correct, carry on using the chain will wear the sprockets out prematurley, the sprockets will end up being pointed, the stretched/worn out chain will cause this, as it doesn't mesh correctly with the sprockets. I reckon you probably should get 3 chains to one set of sprockets, if you change the chains early enough, side ways play should tell you when a chain is worn out.
