coldcake Posted October 5, 2006 Report Share Posted October 5, 2006 just bought 06 sy250,what's the best oils for it.i mean 2 stroke and gear oil? any other tips would be help full Quote Link to comment Share on other sites More sharing options...
baldilocks Posted October 5, 2006 Report Share Posted October 5, 2006 I used PJ1 siver fire two stroke in mine at 65:1 and silkolene light gear oil in the gearbox. No problems with either. Scorpas are pretty bullet proof really just loctite the sprocket bolts, not much else comes loose. Its worth turning the HT coil upside down so that the plug lead runs up the frame tube rather than round the barrel (you'll need to extend the other lead with a connection ) , also zip tie the clutch hose so that its not touching the barrel. both of these mods are just to stop the barrel cooking the lead / hose when it gets relly hot. Apart from that clean the filter and carb every week as its easier to do in the garage than on a windy hillside and everything else should be fine. Quote Link to comment Share on other sites More sharing options...
chap Posted October 7, 2006 Report Share Posted October 7, 2006 I use silkolene light gear oil and ipone synthetic 2 stroke at 50:1. It seems to run fine. But it depends on what oil u prefer. I put a flap of rubber along the top of the air box which helped in wet and muddy trials like shown in the picture. Also silicon between the airbox and the exhaust. Check the bolts on ure mud gard are tight because they have a tendency to cume loose. Also clean the carb and air filter frequently. Hope this is of help. Quote Link to comment Share on other sites More sharing options...
hely1100 Posted October 19, 2006 Report Share Posted October 19, 2006 I use BRADOL Jerez to 1,1% (1:90) only Trial, for raids improve to 1,4% For clutch GRO (Global Racing Oil) Gear. The bike has improved considerably Best regards Quote Link to comment Share on other sites More sharing options...
dfwilson Posted October 20, 2006 Report Share Posted October 20, 2006 Motul 800 at 80:1 Mobil 1 Synthetic ATF in the gearbox Quote Link to comment Share on other sites More sharing options...
markc Posted April 23, 2009 Report Share Posted April 23, 2009 Bringing up an old thread: For the gerabox; is it gearbox oil (which is usually 75w-90), ATF fluid, or 10w-30 engine oil (according to a 2003 owner's manual it reads SAE 10w-30)? Thanks, Mark Quote Link to comment Share on other sites More sharing options...
g520 Posted April 23, 2009 Report Share Posted April 23, 2009 Hi If you are new to Scorpa, here you have some info. The Scorpa SY250 has a clutch that may stick. The engine oil will make a difference, some oils will lessen/eliminate the problem, other oils will not. I got my scorpa sy only a few months back so I am not an expert. But FWIW I had a bad problem with the clutch. It would not only stick when I started the ride but even after having the engine off for only a few minutes the clutch would stick again. I don Quote Link to comment Share on other sites More sharing options...
scorpa4banger Posted April 23, 2009 Report Share Posted April 23, 2009 Hi Lads I use Belray gear saver 75 in the gear box 600ml and motul 2T 800 Factory line for premix 70 -1 wd40 all over the bike and chain ( not the discs ) mothers plastic protector ( smells like flowers ) on the plastics nulon disc clean on the discs and tyre shine silicone spray on the tyres ( usually helps mud stain and cow crap wash off easier ) loctite stud lock on the sprocket bolts and plenty of water proof grease on the handle bar single bolt clamps if you have that style ( I think the 06's ad the two bolt ones ) also check the the exhaust flandge on the motor dosnt leak if it does stick some copper grease on it and refit also helps to get rid of the standard air filter and stick in a jitsie one get rid of the standard chain and put a DID gold racing chain on there 520 light duty ( forget the part number ) also invest in a carbon exhaust pipe protector and on the silencer well worth the money I also run a BKR6EIX eridium plug they work great, if you can get them trade price its worth it and one last one if you can afford it put some apico leavers on and stick the ajp ones in the tool box sorry for all the dribble just things that I did and have been helpful although I ride my bike nearly every weekend of the year so it gets some use cheers Quote Link to comment Share on other sites More sharing options...
