andyh Posted October 7, 2006 Report Share Posted October 7, 2006 Hi all i am in the process of dismatling my TY250 mono forks jap inport to change fork seals. the screw holding the damper inside the slider is just turning as is the damper rod inside. it looks like a special tool is needed to stop it spinning. anyone got a suggestion as to what i could use. i do not have a manual. download anywhere? is 300ml of oil ok for an average rider? thanks in advance. andyh Quote Link to comment Share on other sites More sharing options...
paioli Posted October 7, 2006 Report Share Posted October 7, 2006 leave frount end in bike complete,drain oil from forks, compress frount end and hold with bike tie down, now try to ease bolt out , try 280cc oil to start with. Quote Link to comment Share on other sites More sharing options...
andyh Posted October 7, 2006 Author Report Share Posted October 7, 2006 Many thanks. eventually used a wooden broom handle tapered which slotted in and locked the rod. dropped the front end complete and removed each oil seal with wheel, mudguard and forks still together. worked fine. i'll try 280ml. many thanks andyh Quote Link to comment Share on other sites More sharing options...
kevin j Posted October 13, 2006 Report Share Posted October 13, 2006 I will post a pic of a tool on the thread about TY175 forks kcj Quote Link to comment Share on other sites More sharing options...
