north_yorkshire_lad Posted October 13, 2006 Report Share Posted October 13, 2006 does anyone know where i can purchase a lighter throttle spring for my keihin, when we had the carb fitted to the bike (06 125) the throttle seemed to be heavier than everyone elses. cheers Quote Link to comment Share on other sites More sharing options...
coxy Posted October 13, 2006 Report Share Posted October 13, 2006 take your throttle spring out of your carb and cut it down two to three turns but do it a little at a time until you are happy but dont go too far otherwise it`ll not spring back, maybe also give all the throttle a really good clean aswell and use only a tiny bit of grease on the bars just enough to give it a thin coat otherwise this will also affect the performance Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted October 14, 2006 Report Share Posted October 14, 2006 Much better way is to grind a little material off the spring a it one way then the other , good way to take a bit off and maintain the position and spring length both important. have a spare in case you do too much. Quote Link to comment Share on other sites More sharing options...
north_yorkshire_lad Posted October 14, 2006 Author Report Share Posted October 14, 2006 cheers i'll give it a go Quote Link to comment Share on other sites More sharing options...
baldilocks Posted October 15, 2006 Report Share Posted October 15, 2006 Dont forget the cable, I run wd40 or gt 85 down the cable once a month, disconnect from the carb end first. this makes the throttle feel lighter as well. Quote Link to comment Share on other sites More sharing options...
north_yorkshire_lad Posted October 15, 2006 Author Report Share Posted October 15, 2006 cheers Quote Link to comment Share on other sites More sharing options...
