penno350 Posted October 22, 2006 Report Share Posted October 22, 2006 My 159 will kick up ok on choke and run fine although it needs the odd blip to keep it going when the choke is off. However, after about a minute from starting it just dies as if there is no fuel getting through. It's fitted with a Bing Carb. Any suggestions or tips gratefully received. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted October 22, 2006 Report Share Posted October 22, 2006 Float level, adjust so it fills by bending the brass bits up a bit. Quote Link to comment Share on other sites More sharing options...
penno350 Posted October 22, 2006 Author Report Share Posted October 22, 2006 Thanks Nigel, I changed the float assembly and spotted that the needle had slipped up inside the slide and the needle circlip was caught on the spring which was holding it high re-seated it and its working . Quote Link to comment Share on other sites More sharing options...
legs Posted October 22, 2006 Report Share Posted October 22, 2006 The breather tube which runs from side to side should HAVE a hole in it... so if you have replaced this tube cut a hole in it..... Quote Link to comment Share on other sites More sharing options...
