superhondaman Posted October 22, 2006 Report Share Posted October 22, 2006 Had a problem with my 200 a while back it seemed like it had killed a plug,then it got worse would run ok 2/3rd's of the trial then start to feel as though its 4 stroking?, i replaced the main coil, ok again for a couple of trials, then it started again, plug colour is fine, had the small coil behind the flywheel rewound, and its still 4 stroking, could the timeing be out? when i replaced the coil the lines were 'in line' on the flywheel. Any help appreciated! Quote Link to comment Share on other sites More sharing options...
feetupfun Posted October 23, 2006 Report Share Posted October 23, 2006 Why are you so sure it is an electrical problem? If it is 4 stroking, it may be the fuel/air mixture is too rich. There are many things that can go wrong to cause an intermittent rich mixture. Helping to diagnose the problem needs more info. Under what riding conditions does the 4 stroking happen ie throttle position, bike attitude, engine warm or cold, RPM sensitive, during accelleration or constant speed, anything coming out the float bowl overflow, does it go better after you turn the fuel tap off? Quote Link to comment Share on other sites More sharing options...
superhondaman Posted October 24, 2006 Author Report Share Posted October 24, 2006 Ok just been in the garage,checked carb cleaned it out all fine new plug in. On starting at cold running badly when you try to open the throttle its missing but i noticed that after a second the blue exhaust smoke changed to black, as the revs went lower it would return to normal colour.checked the plug and it is now black and oily. It is missing, 4 stroking, running rough cold or hot. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
lee harris Posted October 26, 2006 Report Share Posted October 26, 2006 I would drain the gearbox oil to check to see if its all there. i had a minarelli crank seal go on mine last year and that woz difficult to diagnose but easy to cure! lee Quote Link to comment Share on other sites More sharing options...
axulsuv Posted October 26, 2006 Report Share Posted October 26, 2006 Crank Seals leaking ? (trying to burn gear oil !?) Glenn Lee we were typing at the same time ! Brilliant minds must think alike !... Glenn Quote Link to comment Share on other sites More sharing options...
superhondaman Posted December 23, 2006 Author Report Share Posted December 23, 2006 On checking the timing i noticed that the pick up from the flywheel which is held onto the stator plate was loose. After tightening the 2 screws the bike runs fine! anyone else had this problem. Quote Link to comment Share on other sites More sharing options...
axulsuv Posted December 24, 2006 Report Share Posted December 24, 2006 That works for me ! I've never had mine come loose , but that could definitely change the timing enough , Or cause the spark to be intermittent , to do what you described as the running condition of the bike ! Would it randomly be a witch to start to ? possible starter lever kickbacks ???? Sorry for the worst case Internet diag.................... Keep the FANTICS alive !!!! Glenn Quote Link to comment Share on other sites More sharing options...
