rapid roy Posted October 24, 2006 Report Share Posted October 24, 2006 does anyone know what volume in each leg does anyone know where i can get a workshop manual for this model cheers Quote Link to comment Share on other sites More sharing options...
hugo Posted May 10, 2007 Report Share Posted May 10, 2007 (edited) I was looking for the same information and I see that your post stayed without any replies for a few months... Well, here's what I found on the sherco USA website, concerning all full size 06 models, not just the 125. Oil types and levels for the 2006 trials models Paioli front forks Oil level on right leg: 60mm With forks at bottom Quantity: 370 +/- 4 ml Oil level on left leg: 110mm With forks at bottom and without spring Quantity: 385+/- 4 ml It's a bit more oil than in the previous Shercos (my 2004 required 330ml if I remember correctly). In case you want to download the pdf, here's the link: http://www.shercousa.com/pdfs/2006fork.pdf Hugo Edited May 10, 2007 by hugo Quote Link to comment Share on other sites More sharing options...
