honda pants Posted October 24, 2006 Report Share Posted October 24, 2006 Can anyone suggest the best combination of front and rear sprocket to suit the 200 seeley, 520 chain size. And who does the fork seals ta! Quote Link to comment Share on other sites More sharing options...
woody Posted October 24, 2006 Report Share Posted October 24, 2006 Not sure about the gearing but front forks are same type as 200 Fantic etc - 35mm Marzzochis, so any of the trials dealers should stock them. Or just match them up at your local bearing/seal company. Quote Link to comment Share on other sites More sharing options...
honda pants Posted October 25, 2006 Author Report Share Posted October 25, 2006 Not sure about the gearing but front forks are same type as 200 Fantic etc - 35mm Marzzochis, so any of the trials dealers should stock them. Or just match them up at your local bearing/seal company. Woody thanks for that do you know the cc's per leg when replacing oils ? Also i have a spare set of Marzzochis from a Fantic or Swm i cant remember which one But the diameter of the sliders is 34mm but you are right about the seeley legs they are 35m thanks Quote Link to comment Share on other sites More sharing options...
woody Posted October 25, 2006 Report Share Posted October 25, 2006 Recommended oil quantity is 220cc per leg so I'd use that as a starting point and fine tune to your liking. Same with the oil weight - personal choice really. I've never heard of 34mm Marzzochis, if they're forks from a Fantic or SWM they should be 35mm. Some very early Fantics used 32mm. Later SWM used Betor Quote Link to comment Share on other sites More sharing options...
zisko62 Posted October 25, 2006 Report Share Posted October 25, 2006 Hi, the first SWM (red and white) had a 34mm Marzocchi. There were also 34mm forks with special magnesium lower legs!! cheers from Italy Quote Link to comment Share on other sites More sharing options...
honda pants Posted October 25, 2006 Author Report Share Posted October 25, 2006 Hi,the first SWM (red and white) had a 34mm Marzocchi. There were also 34mm forks with special magnesium lower legs!! cheers from Italy Hi thanks for that i remember these were off a early SWM with Magnesiun lower legs. Not much use to me so they can go on Ebay in the next week or so. Quote Link to comment Share on other sites More sharing options...
tljm Posted October 27, 2006 Report Share Posted October 27, 2006 Hi Honda pants, In a TL 200,same RS engine than Seeley, original front sprocket 12T and rear 55T (pitch chain 428) this combination works really fine for trials. Quote Link to comment Share on other sites More sharing options...
honda pants Posted October 29, 2006 Author Report Share Posted October 29, 2006 The sprockets on my Seeley are ;-front 10 rear 44 does anyone have the same on thiers any comments would be great Quote Link to comment Share on other sites More sharing options...
pegasus Posted October 30, 2006 Report Share Posted October 30, 2006 Hi, same with mine 10 and 44 th sprockets, workd fine did try a 9 on front and was very slow. Good luck with yours its all down to personal choice. Quote Link to comment Share on other sites More sharing options...
dngrfld Posted September 1, 2010 Report Share Posted September 1, 2010 (edited) Mine came with 11 F 48 R (520). Not trialled it yet, just ridden it around a car park but felt at home doing figure 8's; 1st gear low enough not to push the front out and could stay off the clutch. To confuse the issue Talon list 11 F 45 R as replacement sprockets, which looks a bit high geared to me? To summarise the options here and above: 11-45 = 4.09:1 11-48 = 4.36:1 10-44 = 4.40:1 12-55 = 4.58:1 (TL200 with RS engine as mentioned in thread; and presumably same primary drive and gearbox ratios as Seeley Honda RS engine?) 9-44 = 4.89:1 Edited September 1, 2010 by dngrfld Quote Link to comment Share on other sites More sharing options...
