albert Posted November 5, 2006 Report Share Posted November 5, 2006 Today my 4rt would only select 1st gear and neutral in mid trial.When i got back to the pits i tried to adjust the clutch but made no difference,and is now stuck in 1st.The gear lever moves up and down no problem.Does anyone have any advice?The bike is only three months old. Quote Link to comment Share on other sites More sharing options...
perce Posted November 5, 2006 Report Share Posted November 5, 2006 You've obviously hit the gear lever hard on something & you've broke it! Costs just over a 100 quid to fix at Sandifords. Quote Link to comment Share on other sites More sharing options...
albert Posted November 5, 2006 Author Report Share Posted November 5, 2006 Do you mean something inside the gearbox?And whats involed with the repair?And yes it was after a rough beck section. Quote Link to comment Share on other sites More sharing options...
perce Posted November 5, 2006 Report Share Posted November 5, 2006 That's the one, you've bust something inside the gearbox. Quote Link to comment Share on other sites More sharing options...
mad4it Posted November 6, 2006 Report Share Posted November 6, 2006 Yes this does happen on the 4rt's i have repaired them beforee. What you have done is broken the end off the selector shaft, it is not as bad as it sounds ! Parts are about thirty five pounds if i remember and about an hour and a half's job. Quote Link to comment Share on other sites More sharing options...
doogle Posted November 9, 2006 Report Share Posted November 9, 2006 hour and a half's job. Hour ans a halfs job! That means you charged me Quote Link to comment Share on other sites More sharing options...
mad4it Posted November 10, 2006 Report Share Posted November 10, 2006 Yes doogle but don't forget the broken rear brake caliper bracket i welded and straightened out the rear disc that was buckled and bled the brakes stripped out the rear caliper. Now that was what i call mates rates! Quote Link to comment Share on other sites More sharing options...
doogle Posted November 10, 2006 Report Share Posted November 10, 2006 Oh yeah, I forgot about the other minor faults that I caused during that weekend. You know the old saying 'Treat em mean, and they break!' Ok, you can have the ticket. Quote Link to comment Share on other sites More sharing options...
