ticket2ride Posted November 12, 2006 Report Share Posted November 12, 2006 Anybody know how much gearbox oil goes in a 2004?... Also - what coolant type/levels does you use? Cheers, Quote Link to comment Share on other sites More sharing options...
koevoet Posted November 12, 2006 Report Share Posted November 12, 2006 I am not at home at the moment so I can`t just nip out and check,butI am pretty sure that I put 550ml in mine! as 1 bottle is not enough for two changes..How does yours start by the way as mine is a pain from cold,taking at least 5 minutes,fine when hot though. I think the choke is not working so I need to strip the carb when I get a chance. Quote Link to comment Share on other sites More sharing options...
edster191 Posted November 12, 2006 Report Share Posted November 12, 2006 It takes 0.52 ltr at drainig, 0.55 ltr at dismantle. Drain bolt torque 22N-m. Hand book recommends 50/50 coolant and distilled water. Quote Link to comment Share on other sites More sharing options...
ticket2ride Posted November 12, 2006 Author Report Share Posted November 12, 2006 No idea... I haven't had a chance to ride it yet......picked it up yesterday....stripping it down at the moment... Do any of you guys know: what the standard gearing should be for a 2004? how to get the swinging arm out?.....it seems like the linkage bearings could do with replacing....I've stripped it down as much as I can...but the arm doesn't seem to look like it will ever come out...!! Cheers, Quote Link to comment Share on other sites More sharing options...
ticket2ride Posted November 12, 2006 Author Report Share Posted November 12, 2006 cheers... kitchen floor more like....and I've got about 1hr before the missus gets back..!!!!! any ideas on the gearing? Quote Link to comment Share on other sites More sharing options...
ticket2ride Posted November 18, 2006 Author Report Share Posted November 18, 2006 yes - at last....bit of a twist and pull....couple of extra sets of hands...on the kitchen floor it fell..!! bearings replaced - today I will mostly be trying to put the think back together.... Cheers Quote Link to comment Share on other sites More sharing options...
