springer Posted November 13, 2006 Report Share Posted November 13, 2006 Can anyone advise on starting a 2002 Montesa when cold. Having not started it for a couple of weeks it takes around 20 to 30 kicks if I'm lucky. Once its warm then starting is okay. I have checked the plug which seems okay, and yes it's wet after all that effort. Ideas and comments please, has any one else had this problem? Quote Link to comment Share on other sites More sharing options...
trialsurfer Posted November 13, 2006 Report Share Posted November 13, 2006 When you shut the bike off for the day turn the petcock off and let it run most of the fuel out. Quote Link to comment Share on other sites More sharing options...
tesamon Posted November 13, 2006 Report Share Posted November 13, 2006 Howdy, Had the same problem on a 03 that drove me nuts for 6 months. Take a finger tip full of grease and coat the brass choke rod with it. Try starting, if it fires right up, you have a brass dust coated "O" ring in the top of your choke housing. The brass rod scrapes against the steel washer that holds the "O" ring in place the shavings get traped between the "O" ring and the rod and will not pull fuel out of the float chamber. Cheers, Tesamon Quote Link to comment Share on other sites More sharing options...
springer Posted November 14, 2006 Author Report Share Posted November 14, 2006 Thanks, It worked! One cotton bud of grease (fingers to large), and it fired up on third kick, I'll now strip the carb down for a clean. Rgds Andrew Quote Link to comment Share on other sites More sharing options...
