Montesa 315r
springer
Can anyone advise on starting a 2002 Montesa when cold. Having not started it for a couple of weeks it takes around 20 to 30 kicks if I'm lucky. Once its warm then starting is okay. I have checked the plug which seems okay, and yes it's wet after all that effort.
Ideas and comments please, has any one else had this problem?
Howdy,
Had the same problem on a 03 that drove me nuts for 6 months. Take a finger tip full of grease and coat the brass choke rod with it. Try starting, if it fires right up, you have a brass dust coated "O" ring in the top of your choke housing. The brass rod scrapes against the steel washer that holds the "O" ring in place the shavings get traped between the "O" ring and the rod and will not pull fuel out of the float chamber.
Cheers,
Tesamon
