jonny beta Posted November 17, 2006 Report Share Posted November 17, 2006 To oil an air filter in a pro or not?? thanks Quote Link to comment Share on other sites More sharing options...
motojojo Posted November 17, 2006 Report Share Posted November 17, 2006 Yes, but put your patience hat on. Quote Link to comment Share on other sites More sharing options...
telecat Posted November 18, 2006 Report Share Posted November 18, 2006 Yep always oil it. Even applies in dry weather where the Dust can cause you problems if it gets into the cylinder. As for patience I had problems getting the filter in the first couple of times but seem to "have the knack" now! Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 18, 2006 Report Share Posted November 18, 2006 some people do it easier with their left hand others like me who take the airbox off a fair bit do it then. My best solution is to carefully remove the wing nut from the thread, cut through weld, and replace with a knob. some people do it easier with their left hand others like me who take the airbox off a fair bit do it then. My best solution is to carefully remove the wing nut from the thread, cut through weld, and replace with a knob. Oil in dry conditions is more important than wet. I Always oil and use the proper stuff it is sticky for a reason. Quote Link to comment Share on other sites More sharing options...
paul w Posted November 18, 2006 Report Share Posted November 18, 2006 always clean and oil with proper filter oil after every ride, best way is to have two or three filters, that way you can remove the dirty one and replace immediately with a clean oiled one. Quote Link to comment Share on other sites More sharing options...
gizza5 Posted November 18, 2006 Report Share Posted November 18, 2006 some people do it easier with their left hand others like me who take the airbox off a fair bit do it then. My best solution is to carefully remove the wing nut from the thread, cut through weld, and replace with a knob.some people do it easier with their left hand others like me who take the airbox off a fair bit do it then. My best solution is to carefully remove the wing nut from the thread, cut through weld, and replace with a knob. Oil in dry conditions is more important than wet. I Always oil and use the proper stuff it is sticky for a reason. There's an echo Quote Link to comment Share on other sites More sharing options...
perce Posted November 18, 2006 Report Share Posted November 18, 2006 Old codger's off senile He is right though, far easier to put the air filter in left handed when the airbox is on the bike. It is an aquired knack though. Quote Link to comment Share on other sites More sharing options...
