dixie Posted November 28, 2006 Report Share Posted November 28, 2006 (edited) who has fitted what??? does the old 315 master sort the on off clutch or another brand?? what have you fitted??? is the hydraulic hose fitting the same thread size on most trialers,ajp seem to make most of the components Edited November 28, 2006 by Dixie Quote Link to comment Share on other sites More sharing options...
sirhc Posted December 1, 2006 Report Share Posted December 1, 2006 I'm suprised nobody else has answered yet, my bike came with the larger master cylinder already installed so I don't know if the fittings are stock or not without looking at another 4rt. I have been playing with the camera so here's a picture so maybe you can tell. Quote Link to comment Share on other sites More sharing options...
hughesy Posted December 1, 2006 Report Share Posted December 1, 2006 (edited) so I don't know if the fittings are stock or not without looking at another 4rt Yes, that's the same MC as fitted to the 315, it's a straight swap job including lever, the hose is exactly the same. does the old 315 master sort the on off clutch or another brand??what have you fitted??? is the hydraulic hose fitting the same thread size on most trialers,ajp seem to make most of the components Just fitted the larger MC and it definitely gives a smoother more progressive action but doesn't totally eliminate drag, or at least it hasn't on mine. like I said above the hose is interchangeable. Edited December 1, 2006 by Hughesy Quote Link to comment Share on other sites More sharing options...
