Brake Blocks
mutznutz
Are you running a grind or a smooth rim?
If you're running a smooth rim then ZOO! pads are the best if you can still get them anywhere.
If you are running a grind then you'll be pretty much alright with whatever.
Have a look on tartybikes.co.uk they are pretty much THE UK bike trials dealer, and the website explains everything, plus explains what the pads are good for.
I'm running onza Citrus pads (because they are cheap) on a smooth rim with a little tar, and they are surprisingly good, however any brake on a smooth rim will die very quickly in the wet - be warned.
Bob
:wacko:
Plazmatic pads!!!!! They are the best all around.
http://www.trialsin.com/sell/pieces/pframe.htm
They sell themin the uk too.
I use the v pads without a grind in snow and I still have 1 finger braking. My stock has hs33 crm and the braking is good in snowy conditions.
