95 Beta Techno 250 Knocking Noise
greenlaning xt
New to this forum
Would like a bit of advise, have just got hold of a 95 250 Beta Techno.
It had an engine rebuild and was run for a while before being laid up for about a year until now.
When we started it, there is knocking noise from the clutch area, there should be no problems in there, and we suspect its the clutch that has dried out and causeing clutch chatter. Have come across this on other bikes, but not quite as load as this.
Anyone come across this, any advise.
www.greenlaning.co.nr
hi there had this problem with an old bike of mine what you need to do is ... drain the oil out of your bike then take the cluch out.. Then get some wet and dry and on the plates that are smooth go round and clean them all up.. Then put all your cluch back to geather fill your bike with good high quality oil and away you go !! That should fix your problem hope this helps you . jamie .
