anyhill Posted March 22, 2004 Report Share Posted March 22, 2004 can anyone suggest what the best chain & sprockets to use are? Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted March 22, 2004 Report Share Posted March 22, 2004 Iris trial pro, just like Dougie! Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted March 22, 2004 Report Share Posted March 22, 2004 I will now stand upon my well-worn soapbox and sing my old tune...Ahem... If you buy an o-ring chain, it will not wear out, so a worn-out chain will never wear out your sprockets. You'll get several seasons out of your sprockets, the chain will last indefinitely, you'll never adjust it, and maintenance will consist of washing it off when you wash the bike and spraying on some silicone to preserve the o-rings. Quote Link to comment Share on other sites More sharing options...
beta boy Posted March 22, 2004 Report Share Posted March 22, 2004 iris trials chain and talon sprokets Quote Link to comment Share on other sites More sharing options...
hrc2002 Posted March 22, 2004 Report Share Posted March 22, 2004 Using Iris Trials Pro chain, with a talon front sprocket and a SuperSprox, never had a Supersprox but they are impressive!! Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted March 23, 2004 Report Share Posted March 23, 2004 Just try spinning the back wheel after finishing a southern trial on an o ring chain and make up your own mind.O ring, never! Quote Link to comment Share on other sites More sharing options...
wonder boy Posted March 23, 2004 Report Share Posted March 23, 2004 Dont see the point in and iris chain i have a a RK chain i like half the price and does the job just the same. Gavin Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted March 23, 2004 Report Share Posted March 23, 2004 Gav whats the cost of both? Where from? Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted March 23, 2004 Report Share Posted March 23, 2004 Nigel Dabster said: Just try spinning the back wheel after finishing a southern trial on an o ring chain and make up your own mind.O ring, never! I've never tried spinning the back wheel after finishing a southern trial on an o-ring chain. What would happen? Quote Link to comment Share on other sites More sharing options...
anyhill Posted March 23, 2004 Author Report Share Posted March 23, 2004 My old chain kept coming off and wrapping round the front sprocket, i guess i'm lucky i havn't broken something in the gearbox. When i get my new chain & sprockets, how tight should i have the chain? Quote Link to comment Share on other sites More sharing options...
the artist formerly known as ish Posted March 23, 2004 Report Share Posted March 23, 2004 Anyhill, 10mm between the tensioner rubber and the swingarm, too tight and it will pull on the counter shaft and could make the seal leak, too slack and it will slap around and come off, but better a little slack than too tight. Quote Link to comment Share on other sites More sharing options...
anyhill Posted March 23, 2004 Author Report Share Posted March 23, 2004 cheers ishy Quote Link to comment Share on other sites More sharing options...
anyhill Posted March 25, 2004 Author Report Share Posted March 25, 2004 FYI; Purchased Iris chain & Talon sprockets from Tony K @ <mention of this company is not permitted on Trials Central>/trials.html Cost me Quote Link to comment Share on other sites More sharing options...
