spudsdad Posted December 21, 2006 Report Share Posted December 21, 2006 has anyone tried any differant reeds eg, aktive ,boysen or v force reed block. what results have you had ? any better than standard? very interested in feedback on the v force reed block. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted December 21, 2006 Report Share Posted December 21, 2006 Boyesen are very good for the Sherco, nicer all through with a dellorto and better at the top end too. I have a new set here if you want them? Quote Link to comment Share on other sites More sharing options...
north_yorkshire_lad Posted December 21, 2006 Report Share Posted December 21, 2006 (edited) Nigel Dabster said: Boyesen are very good for the Sherco, nicer all through with a dellorto and better at the top end too.I have a new set here if you want them? how are they on gassers (a 125) Edited December 21, 2006 by north_yorkshire_lad Quote Link to comment Share on other sites More sharing options...
n.wales_sherco_lad1 Posted January 3, 2007 Report Share Posted January 3, 2007 i tried my kehin carb but wasnt runnig right. ive had the jets changed and different needle slides and positions but still wasnt right. should i change the reed to a different 1. should this help and what reed would you recormend? thanks scott Quote Link to comment Share on other sites More sharing options...
johnnysherco Posted January 5, 2007 Report Share Posted January 5, 2007 Hello Scott We are running a 06 125 fitted with V-Force reeds and a Kehin carby, with the squish band reset and the flywheel lightened it is a real potent 125 and can rev as fast as you want it to. The V-Force reeds are good and well worth fitting and then spending the time jetting and timing the engine to make it all work happy new year Johnnysherco Quote Link to comment Share on other sites More sharing options...
