blocky Posted December 22, 2006 Report Share Posted December 22, 2006 I've started stripping the engine from my TX250 (This is the 125cc one with the minareli engine) and I have a few questions... 1. Should there be a gasket between the engine and clutch cover? There wasn't one there when I took the cover off which seems very strange. 2. I think I read somewhere that the flywheel puller was the same as a Yamaha one. Is this correct? and if so which Yam is it? 3. Should there be a lock tab under the main nut which holds on the clutch basket? Looks like someone has been here before me Quote Link to comment Share on other sites More sharing options...
