Rebore Required ?
arun1664
I have just brought myself a 200 with a top end rattle, I removed the barrel & checked the ring gap a) at the very top of the barrel and then :beer: immediatly below the step, and there is a 0.5mm diffrence which I think tells me it needs a rebore. all the bearings seem fine, so;
Any thoughts before I go spend my money on a rebore?
What oversizes are available for the 200? (2002 model if that matters)
I was surprised to find the bike has a steel liner, I had assumed it would be nickasil.
Anyhow thanks in advance, and a happy new year to all. :thumbup:
I think from memory that the 200 is the only Beta with a steel liner, its actually a sleeved 250 barrel but this info comes from a TMX test of the first 200. I would suggest you ring lampkins not langcourt, your going to need a new piston either way from Lampkin so best get the facts first.
Thanks Baldilocks, the liner is indeed steel. For others info, I phoned Lampkins who confirmed that the earlier 200's are steel lined. Also told me that beta only do 1 oversize that I am pretty mine is already on. They did however put me onto Birketts who have found a piston that will take the bore out further, so mine is off to them in the post tomorrow. Anyhow will add a post when I get it back, the info may be useful to other 200 owners.
