New Engine Any One ?
jamie stokes
  • Replies 38
Jamie,
There is one other option and that is to look through the bike breakers ads. I don't know whether you'll find anything and I'd still advocate going to MRS or any other Sherco dealer you know.
I'd be very surprised if you did not benefit from putting the proper parts in.
cheers
Donald
Hello Jamie
To change the big end bearing you have to press apart the crank and you cannot reuse the crank pin again.
The parts book gives you a crank repair kit part no R212 which includes crank pin, bearing, and con rod all of which you need to do a proper job! Any good motorcycle repair shop will be able to press apart the crank and refit the new parts and align and balance the crankshaft.
Happy new year
Johnnysherco
