ronoc88 Posted January 5, 2007 Report Share Posted January 5, 2007 (edited) Chaps Just wondering if any of you could tell me which chain i would need for a 2000 GasGas 250 txt? Iris 520x100 RXL Edited January 5, 2007 by ronoc88 Quote Link to comment Share on other sites More sharing options...
leggins Posted January 5, 2007 Report Share Posted January 5, 2007 DONT BUY IRIS DONT BUY IRIS DONT BUY IRIS DONT BUY IRIS Quote Link to comment Share on other sites More sharing options...
fantic156 Posted January 5, 2007 Report Share Posted January 5, 2007 Don't buy an IRIS they snap a lot Read the thread titled, Chains, Wd40 & All That in mechanical talk for more info. I've always been told and used 102 links on trials bikes. Quote Link to comment Share on other sites More sharing options...
essex rider Posted January 5, 2007 Report Share Posted January 5, 2007 that will be the general point made in this thread Get a renthal or regina or DID one in the longest length so it can be cut down if neccessary Quote Link to comment Share on other sites More sharing options...
ask greeves Posted January 6, 2007 Report Share Posted January 6, 2007 Hello Ronoc 88, Best thing to do, is to remove the old chain and count the links. Count them more than once just to be sure. Make sure you end up with an even number, an odd number could indicate that at some time a half link could have been inserted as a stop gap measure. As previously stated, always buy the longest chain and cut down to size, if you bought a 'too short' chain you would have to extend it with another split link, as split links are the weak link, the chain would be twice as likely to fail. So maybe buy a quality chain and also a chain link extractor tool. When fitting the spring link make sure the sprung steel clip, faces in direction of rotation. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted January 6, 2007 Report Share Posted January 6, 2007 I love Iris Raga uses them so they can't be that bad. The lightweight ones are cheap enough to have a couple a year. Quote Link to comment Share on other sites More sharing options...
ham2 Posted January 6, 2007 Report Share Posted January 6, 2007 The timing of this couldn't be better. I was out on my bike last night and snapped my Iris chain quite dramatically. It whipped across my foot, which is still bloody sore this morning and if it wasn't for my boot I would be in a sorry state. I need a new slave cylinder now. Motto :- Buy the best kit you can afford i.e. not Iris. Quote Link to comment Share on other sites More sharing options...
cdn280 Posted January 6, 2007 Report Share Posted January 6, 2007 I love Iris Raga uses them so they can't be that bad. The lightweight ones are cheap enough to have a couple a year. You love a chain ? And a couple a year? I've only used DID, Regina, Sidewinder, AFAM (or was that just sprockets?) and only go thru them every 2 yrs or more when i change the sprockets. The only one I had a problem with was a stock Kawi DID chain that broke 1 side plate when a rock got in the chain/sprocket. I wouldn't cheap out on a chain on a bike with a 10 or 11 tooth front sprocket. That tiny sprocket is harder on them than any other abuse you can do to them, especially at trail/road speed. Which reminds me, i need to replace the original one on my 2002. Quote Link to comment Share on other sites More sharing options...
north_yorkshire_lad Posted January 6, 2007 Report Share Posted January 6, 2007 Renthal offer the best quality chain, but you do save a bit of weight with the Iris (even if they do break alot ) it's all about how much money you jave to spend and what you want to spend it on Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted January 6, 2007 Report Share Posted January 6, 2007 There are always two sides to this, and my take on it is for alot an Iris is fine. Put your bike on a stand and pressure wash the back wheel. Tell me which chain has least resistance. An iris. I think that as a Renthal is probably unbreakable then it must have more drag. Guys use wd 40, I don't. Horses for courses. Quote Link to comment Share on other sites More sharing options...
andy_290 Posted January 6, 2007 Report Share Posted January 6, 2007 Don't buy an Iris, if you can "stretch" to a renthal (pun intended) Quote Link to comment Share on other sites More sharing options...
