blocky Posted January 8, 2007 Report Share Posted January 8, 2007 Please forgive me for such a dumb ass question but i've just replaced the crankshaft seals on my TX250 (Minarelli engine) and for the life of me i can't work out where to refil the gearbox with oil. I can see what may be a filler cap near where the clutch cable pivots but i'm reluctant to force it because its only plastic and is more than finger tight. Thanks Quote Link to comment Share on other sites More sharing options...
lee harris Posted January 8, 2007 Report Share Posted January 8, 2007 Yep thats it, on the top near to the clutch cable holding boss. If you bu%&er it or use another screw, make sure it has a breather hole in it or you will damage the crank seals as the crank cases cannot vented if there is no hole. lee Quote Link to comment Share on other sites More sharing options...
chris morris Posted January 8, 2007 Report Share Posted January 8, 2007 (edited) Remove the oil level plug circled in the pic lay the bike on its side and fill it thro' there or remove the four screws on the polished clutch cover and pour directly into there. I feel so dumb too, dont think your on about a gasgas tx250 are you. Edited January 8, 2007 by Chris Morris Quote Link to comment Share on other sites More sharing options...
blocky Posted January 8, 2007 Author Report Share Posted January 8, 2007 Thanks Lee... Guess i'll just have to be a bit more firm with it then. Thanks for you time and effort too Chris although yes I was talking about a Fantic Quote Link to comment Share on other sites More sharing options...
fantic303 Posted January 8, 2007 Report Share Posted January 8, 2007 Hi, I have some pictures from a manual: Pic 1 : Oil filler cap (Black screw) Pic 2 : Oil drain plug Pic 3 : Oil level screw Quote Link to comment Share on other sites More sharing options...
