Replacing Rear Linkage Bearings. Pro 05
charlie
try these hk1520 2rs
you`ll find that the bearing-seal arrangement from new has a pissy little seal on each side of the bearing.
the bearings above have the seals incorperated into them and end up the same width (20mm)
think they're about
Edited by Chris Morris
if your on about the rear suspension linkage bearings its a doddle to do just take the rear wheel out and undo all the nuts and bolts holding it together and also the suspension bolt at the top and then the linkage bearings just get a socket which will fit just inside the hole and on top of the bearings them selves and just tap them quite hard ansd they should come out and then go to your dealer or bearing shop and take all the bitsd and peices with you from the bearings and tell them you want some more including bushes and just tap them in with a bit of grease like how you tapped them out and grease the bearings really well and then put it all back together and it should be ok
(by the way it may not be the rear linkages that have got movement in them as my rear end has movement in it but i have tried everything and can`t get it to go away!)
coxy
