Compression Test On 290?
ktmsprocket
The compression ratio is near 10:1, cannot recall exact, but that means 140psi or so on the guage would be normal at somewhere near sea level.
It has always been easier to "feel" the kickstart lever resistance as compared to a newer bike if you suspect something is wrong.
Other things come into play such as piston rattle that may indicate a problem with wear. :)
