ktmsprocket Posted January 8, 2007 Report Share Posted January 8, 2007 (edited) All, What is the desirable compression test range for a Sherco 290 '03 model? Thanks in advance. ((I presume the test is done with 15 kicks at WOT)) Edited January 8, 2007 by KTMSprocket Quote Link to comment Share on other sites More sharing options...
jamie stokes Posted January 8, 2007 Report Share Posted January 8, 2007 (edited) have a look on shercos web site Edited January 8, 2007 by jamie stokes Quote Link to comment Share on other sites More sharing options...
copemech Posted January 9, 2007 Report Share Posted January 9, 2007 The compression ratio is near 10:1, cannot recall exact, but that means 140psi or so on the guage would be normal at somewhere near sea level. It has always been easier to "feel" the kickstart lever resistance as compared to a newer bike if you suspect something is wrong. Other things come into play such as piston rattle that may indicate a problem with wear. Quote Link to comment Share on other sites More sharing options...
ktmsprocket Posted January 12, 2007 Author Report Share Posted January 12, 2007 I bought it. You need to have the weight of an elephant to kick it over....so i thinkg the compression is good. PS. Flipped it already..... Quote Link to comment Share on other sites More sharing options...
