ktmsprocket Posted January 12, 2007 Report Share Posted January 12, 2007 Hi. Has anybody fighted some 'bright' headlights to the above? If so, what kit did you use? Wattage? Extra running gear? Problems? Cheers Quote Link to comment Share on other sites More sharing options...
ktmsprocket Posted January 18, 2007 Author Report Share Posted January 18, 2007 Bumpo! Quote Link to comment Share on other sites More sharing options...
copemech Posted January 18, 2007 Report Share Posted January 18, 2007 I could not help but check what (watts) my original lamp was. Surprised to find a 5 watt peanut. With elimination of the stop lamp and tail lamp, you should be able to increase that to 10 watts, possibly even a halogen lamp, without killing the ignition when you turn the light on! Best I can tell, there is no separate lighting coil on this setup, one power source runs everything! Quote Link to comment Share on other sites More sharing options...
copemech Posted January 19, 2007 Report Share Posted January 19, 2007 (edited) Found this tidbit. You could run 2, 6V/ 5W halogen lamps in series, or 1, 12V 10W! Or perhaps 2, 12V 5W in parallel! With two, you could look like a 747 coming into the section! http://lightbulbsdirect.com/Merchant2/merc...gory_Code=MR-11 linky Edited January 19, 2007 by copemech Quote Link to comment Share on other sites More sharing options...
ktmsprocket Posted January 19, 2007 Author Report Share Posted January 19, 2007 Too Funny...Copemech.... I think I will just start fiddling about...and stop when something melts. Quote Link to comment Share on other sites More sharing options...
copemech Posted January 19, 2007 Report Share Posted January 19, 2007 I like the idea myself. Imbedded into a CF front plate, these could be wicked! I often ride till dark! Have often wished I had the stocker! Quote Link to comment Share on other sites More sharing options...
