rapid roy Posted January 19, 2007 Report Share Posted January 19, 2007 DOES ANYONE KNOW OF A COMPANY THAT SELLS REBUILDABLE REAR SHOCKS FOR THE 125 (06) SHERCO CHEERS Quote Link to comment Share on other sites More sharing options...
matt Posted January 19, 2007 Report Share Posted January 19, 2007 can get an ohlins to fit. there the best available Quote Link to comment Share on other sites More sharing options...
copemech Posted January 20, 2007 Report Share Posted January 20, 2007 There is a new shock available made by Jitsie, find a local dealer and thay should be able to help. Supposed to be quite good! Quote Link to comment Share on other sites More sharing options...
stump magnet Posted January 20, 2007 Report Share Posted January 20, 2007 if your rear shock has packed up speak to MRS as they sorted me out a new 07 rear shock for Quote Link to comment Share on other sites More sharing options...
b8ppj Posted January 25, 2007 Report Share Posted January 25, 2007 if your rear shock has packed up speak to MRS as they sorted me out a new 07 rear shock for Quote Link to comment Share on other sites More sharing options...
stump magnet Posted January 26, 2007 Report Share Posted January 26, 2007 when you get the 07 shock you may have to file a small part of the alloy away around the top eye bolt to fit it in to the frame, the 07 has the shock upside down to the 06 as it has a different swingarm but the 07 shock will not fit the 06 swingarm that way up, dont worry it is very easy to do and only takes ten mins, dont tamper with the frame though, the only disadvantage is that the rebound adjuster is now at the top and to get to it requires taking the airbox out, at least it wont get full of crap and seize up! i set mine to 5 turns from fully in and seems to be fine, im still playing with preload though as i aint sure what the sag should be set to, any one got any ideas? Quote Link to comment Share on other sites More sharing options...
b8ppj Posted January 29, 2007 Report Share Posted January 29, 2007 (edited) when you get the 07 shock you may have to file a small part of the alloy away around the top eye bolt to fit it in to the frame, the 07 has the shock upside down to the 06 as it has a different swingarm but the 07 shock will not fit the 06 swingarm that way up, dont worry it is very easy to do and only takes ten mins, dont tamper with the frame though, the only disadvantage is that the rebound adjuster is now at the top and to get to it requires taking the airbox out, at least it wont get full of crap and seize up! i set mine to 5 turns from fully in and seems to be fine, im still playing with preload though as i aint sure what the sag should be set to, any one got any ideas? Thanks for the information. I spoke to martin at MRS on friday and there was a fault on a small batch off 2006 rear shocks, basically the lower mount was made from a poor grade off casting and as its under alot off pressure after time it streches the threads until it pops out !!!! I have gone for the Edited January 29, 2007 by b8ppj Quote Link to comment Share on other sites More sharing options...
bigdamo Posted January 29, 2007 Report Share Posted January 29, 2007 when you get the 07 shock you may have to file a small part of the alloy away around the top eye bolt to fit it in to the frame, the 07 has the shock upside down to the 06 as it has a different swingarm but the 07 shock will not fit the 06 swingarm that way up, dont worry it is very easy to do and only takes ten mins, dont tamper with the frame though, the only disadvantage is that the rebound adjuster is now at the top and to get to it requires taking the airbox out, at least it wont get full of crap and seize up! i set mine to 5 turns from fully in and seems to be fine, im still playing with preload though as i aint sure what the sag should be set to, any one got any ideas? Thanks for the information. I spoke to martin at MRS on friday and there was a fault on a small batch off 2006 rear shocks, basically the lower mount was made from a poor grade off casting and as its under alot off pressure after time it streches the threads until it pops out !!!! I have gone for the Quote Link to comment Share on other sites More sharing options...
northernnorm Posted January 29, 2007 Report Share Posted January 29, 2007 If you want rebuildable shock check out the TRP we got a loaner from Lewisport and with a little adjustment it works VERY GOOD and it wouldnt take much to beat the reliability of the questionable stuff that Sherco sends on the bikes. Quote Link to comment Share on other sites More sharing options...
