Hello All
fedralseth666
Hi there, im Tim, im new to the trials scene, just bought an 03 scorpa sy 250 to play about on and practice bike handling for the motocross and enduro racing i do.
any riding hints and tip would be great, and maintainence advice?
i just took the air filter out (which looks to contain half or wales) and cleaned around the air box and in the air box. ive dropped the gear box oil and put some motorex light oil in there. im a bit stuck with the sump drain bolt as its seized in and had to drain the sump from the side under the gear shifter, is ok to drain the oil like this every time or should i get the sump bolt removed?
im going to strip the carb sometime this week and clean it all along with changing the spark plug. is there anything else you would do?
cheers for any advice?
