Ty 125 With Dt Cylinder
tljm
DT175s from 1978 onwards have a different stud layout than the TY175. So some DT175 barrels are interchangable with TY175 barrels and some are not.
The TY175 motor is based on the 1974 DT175A so the A, B C and D model DT175 barrels should fit.
I know the question was about the TY125 but I've never worked on one of them.
Why would you want to fit a DT barrel to a TY motor anyway? Is the DT barrel better in some way than a TY175 barrel?
Hi Feetupfun,
The reason of the topic it is not because the DT barrel is better than the TY. I wish to convert a TY125 to 175 but I do not find TY 175 barrel and I found some "old" DT barrel. So it colud be a solution if the DT fits. Anyway if anybody knows where I can find a TY 175 cylinder it will be perfect.
Thank you.
