tljm Posted January 24, 2007 Report Share Posted January 24, 2007 Anybody knows if it is possible to convert one TY125 to 175 using a DT175 cylinder. Does it fit to the TY? Quote Link to comment Share on other sites More sharing options...
scottt Posted January 24, 2007 Report Share Posted January 24, 2007 Not sure about that but the TY175 barrel just bolts straight on, Scott. Quote Link to comment Share on other sites More sharing options...
mattylad Posted January 26, 2007 Report Share Posted January 26, 2007 I cannot be certin for all model years but I have a DT 175 engine where very little fits the TY even the head does not fit so I doubt the barrel will However a DT 250 does dirrectly on a TY 250 and makes it feel much more modern!! Quote Link to comment Share on other sites More sharing options...
feetupfun Posted January 26, 2007 Report Share Posted January 26, 2007 DT175s from 1978 onwards have a different stud layout than the TY175. So some DT175 barrels are interchangable with TY175 barrels and some are not. The TY175 motor is based on the 1974 DT175A so the A, B C and D model DT175 barrels should fit. I know the question was about the TY125 but I've never worked on one of them. Why would you want to fit a DT barrel to a TY motor anyway? Is the DT barrel better in some way than a TY175 barrel? Quote Link to comment Share on other sites More sharing options...
paulthistle Posted January 28, 2007 Report Share Posted January 28, 2007 The DT ports are larger and timed differently. It is designed for a higher in the rpm peak torque. Quote Link to comment Share on other sites More sharing options...
tljm Posted January 29, 2007 Author Report Share Posted January 29, 2007 Hi Feetupfun, The reason of the topic it is not because the DT barrel is better than the TY. I wish to convert a TY125 to 175 but I do not find TY 175 barrel and I found some "old" DT barrel. So it colud be a solution if the DT fits. Anyway if anybody knows where I can find a TY 175 cylinder it will be perfect. Thank you. Quote Link to comment Share on other sites More sharing options...
