Siezed Brake Pistons?
neonsurge
I've just attempted to install new front brake pads for the first time on this bike (GasGas 270TXT) and I think the pistons are siezed. After removing the old pads, I can't push the pistons far enough back into the calipers to install the new pads, let alone get the caliper back onto the disk.
Am I missing a trick here? On my previous bikes I could just push the pistons back into the calipers with a screwdriver, install the pads and off we go. The curious thing is, if I reinstall the old pads, the brake works fine.
I'm befuddled. :huh:
It would be possible for it to be too full of fluid and you are hydraulicly locking it when trying to push it back in far enough for the new pads.
Remove the cover and see if some spills over.
I am assuming that it is moving back and forth fine if the old pads are working and that it is going in some, or I would suggest that the master is incorrectly adjusted.
