Stator, Coil & Cdi Issues...
ticket2ride
I have found that 315's need a resistor type spark plug (ngk ones with an R in the part number) If you don't use these sometimes the motor missfires and generally runs poorly, however if you stop the motor and restart it it will be fine again for a while. If you fit the correct spark plug you get no such problems.
