scoobie Posted February 2, 2007 Report Share Posted February 2, 2007 I've noticed that with the side stand up the spring rubs slightly on the side wall of the tyre. All the spacers are in place and the rear wheel is torqued correctly and runs true. Anyone else had this problem on an 04 290? What did you do apart from the obvious of removing the stand? Thanks, Quote Link to comment Share on other sites More sharing options...
perce Posted February 2, 2007 Report Share Posted February 2, 2007 You're stand's bent, just bend it back so it doesn't touch the tyre. Get hold of the end the stand & pull it the direction you think's right. DON'T take it off, knowing your luck the spring will take your teeth out as you try to put it all back together. Quote Link to comment Share on other sites More sharing options...
betamike Posted February 2, 2007 Report Share Posted February 2, 2007 Hello, my friends sherco did the same and the sidestand was a bit bent like Perce said. We managed to get round this by using a thick zip tye to hold the spring to the arm of the sidestand. This did the trick Cheers Mike Quote Link to comment Share on other sites More sharing options...
scoobie Posted February 2, 2007 Author Report Share Posted February 2, 2007 Cheers guys, I shall bend away on the morrow. Quote Link to comment Share on other sites More sharing options...
dale Posted February 2, 2007 Report Share Posted February 2, 2007 If your stand is bent, then by all means straighten it out - but check that the sidestand bracket hasnt moved - there are 2 allen studs holding it on to the swingarm. Quote Link to comment Share on other sites More sharing options...
