glenn Posted April 4, 2004 Report Share Posted April 4, 2004 Hi Dose any body know what the standard mixture screw settings are. Being a comnplete nonce i have fiddled with it without checking what the standard settings where. I have found out that it makes not a jot of differance to me as i cannot feel any differance anyway so would like to return it to standard and leave it there. Thank Glenn Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted April 4, 2004 Report Share Posted April 4, 2004 Adjust the mixture screw until you get the highest (most efficient) idle. Then adjust the idle speed screw (which just moves the slide) to where you want it to idle. If your idle gets too high while adjusting the mixture, back off on the idle screw. Quote Link to comment Share on other sites More sharing options...
jtt Posted April 4, 2004 Report Share Posted April 4, 2004 Standard settings are usually 1.5 turns from full in. Charlie's technique in easy and usually very effective, I'd suggest you try it. I usually go about 1/4-1/2 turn richer (screw out) than the final setting myself, but that's a personal preferance. Quote Link to comment Share on other sites More sharing options...
superflytx270 Posted April 4, 2004 Report Share Posted April 4, 2004 Hi i think the factory settings are for fuel screw 3.5 turns out from base. The idle is 2 turns out from base but make sure when you screw them in to base you dont tighten them up at all just until you feel the pinch or you'll cause damage. Quote Link to comment Share on other sites More sharing options...
jtt Posted April 4, 2004 Report Share Posted April 4, 2004 Hi i think the factory settings are for fuel screw 3.5 turns out from base. Oops....sorry, superfly is right. I was half asleet and thinking MX again sorry. Quote Link to comment Share on other sites More sharing options...
glenn Posted April 5, 2004 Author Report Share Posted April 5, 2004 Thanks for the replys lad i'll give it a go tomorrow. Cheers Glenn Quote Link to comment Share on other sites More sharing options...
superflytx270 Posted April 6, 2004 Report Share Posted April 6, 2004 (edited) Oh and i found this very valuable piece of info while on my travels when i first got my bike It was on a site that invited you to download it as its like some sort of card thingy which you can laminate or stick in a clear pocket and nail it to your garage or shed wall If you pm me your email address i'll send it to you its a adobe pdf file and is 468kb so is bigger than the max file size allowed for this message. Edited April 6, 2004 by superflytx270 Quote Link to comment Share on other sites More sharing options...
