4rt Chain Guide
the addict
I guess you mean the V-Mar chain guard. If so you have to be careful which chain you use as the guard fits very close to the sprocket. The standard chain is fine but if you add a half link it will foul and dig a small groove in the guard. RK standard and Renthal R1 chains will not fit... :guinness: I now have a DID ERT2 on the self which looks the same size as original but I haven't fitted it yet.
Edited by fantic156
I have to disagree, I'm running a Renthal R1 with a V-mar guard fitted with no problems. It did "bed" in a little but there was enough tolerance in the bolt holes to stop it fouling the chain. :guinness:
Edited by Hughesy
I have to disagree, I'm running a Renthal R1 with a V-mar guard fitted with no problems. It did "bed" in a little but there was enough tolerance in the bolt holes to stop it fouling the chain. :D
Inspired to try again I've just been in the garage and Hughsey is right, the renthal chain will fit. I just didn't try hard enough the first time. :guinness:
Edited by fantic156
