Tx320 Rear Brake Problem
dazza70
My 320 rear brake has stopped working.
I have tried bleeding & pressure bleeding but to no avail.
It feels like the master cylinder isn't working properly.
Is there any adjustment on the master cylinder?
Is there any other things that I can try. :D
Hi dazza 70, i had the same problem on my 320 last year. I took the adjuster from the back brake to the master cylinder (the small threaded bolt that fits into the m-c ) & put a pozee screw driver inside the master cylinder which gives u a better push at it,the brake bled straight away with no problems,or try back bleeding from the calliper. also check your pads. hope this helps.
