slack Posted February 10, 2007 Report Share Posted February 10, 2007 Hello everybody, the topic today for all you to solve is my mates clutch on a GG300pro. it's quite heavy & he says it makes his hand ache after a few laps so he has to use all his fingers to pull the ckutch in.i've got to admit its alot hevior than my scorpa clutch. He's tried bleeding it but it is still the same,any ideas folks. thanks alot. Quote Link to comment Share on other sites More sharing options...
johnq Posted February 10, 2007 Report Share Posted February 10, 2007 The most likely answer is that the clutch plates have swollen slightly, This means taking the clutch basket out and measuring the thickness of all the plates together if they measure more than 9.75mm this is probable the problem, You will need you buy an alternate plate to reduce in down to 9.75mm. Quote Link to comment Share on other sites More sharing options...
opdeweegh1 Posted February 10, 2007 Report Share Posted February 10, 2007 Yep. Thats exactly what the problem is the clutch plates have swollen above the 9.75mm max allowable tolerance, if you remove the clutch plates both friction and steel as they come from the bike and measure them with a vernire caliper you'll see straight away, it might only be as much as 9.85 but believe me it makes all the difference. Mine were about 9.85-9.90, I contacted Kev at gasgas uk and he advised either replace the whole clutch package or buy a thinner steel plate to bring the clutch pack back down to the 9.75 tolerance. I replaced the whole clutch and what a difference. The reason for the clutch plates swelling might be changing to a different oil or perhaps a water contamination in the past as it was with mine, my water pump seal went and all my water ended up in the oil. cheers. Quote Link to comment Share on other sites More sharing options...
lewis_gasgas Posted February 12, 2007 Report Share Posted February 12, 2007 opdeweegh1 how much was the whole clutch ? and how much is it for the steel plate ? obvioulsy single plate going to be cheaper just wondered as mine needs doing and if its not a hellish price for the whole clutch then might just do that. cheers lew. Quote Link to comment Share on other sites More sharing options...
